Manzana Guide?
timliora
Jun 7, 2007
14
Is their a step by step Manzana guide somewhere with pictures?
Do we use Jailbreak...and then when it reboots open up Manzana...or just use Manzana?
Thanks!
princess_80854
657
There is a thread over at modmyiPhone that discusses this. You may find it helpful. Do a quick search there for "Manzana Discussion". I would post the link for you, but I can't get on the site.
dug1200
Aug 1, 2007
Thanks!
there are 2 files that you put in your phonedmg...the dll and exe
jailbreak...once the phone reboots...run the manzanaUI.exe from inside the folder...now just navigate to the folder you need and drag and drop one at a time...doesn't work well if you do multiple at once...well at least not for me.
you need to create the folder for ringtones through the iPhoneinterface....
once you jailbreak once...no need to do it again unless you restore
Witness
Jun 18, 2007
1,471
29
Miami,Florida
LOL its not that hard its just drag and drop, using terminal drove me crazy. Make sure whatever files your replacing in manzana that they have the same name as the old file.
princess_80854
657
after you do this, how do you sync it to your iPhone?
Once you drag and drop the icon into the Manzana apllication, it will be on your phone. You'll need to restart the phone (most times) in order to see the changes you made. That's it.
vballer68
Jul 28, 2007
where can I download it? I have looked everywhere and I can't seem to find it. I use a mac....
bdiddy619
Jun 30, 2007
37
where am i clicking and dragging the file to when im in manzana? im a little confused
