Map Widget Create You Own Location with Pin
rj5620
Jun 2, 2007
70
Is it possible to create a location and apply a pin to it and a bookmark for that location?
pb30
81
Minnesota
1. Search for address
2. Click Blue arrow
3. Add to bookmarks
4. Give it a name
wjp09
Feb 25, 2007
2,559
25
NJ
I think he means manually point and put the marker there. I wish you could because I searched for somethings and it puts it a good bit away when your zoomed in.
psychoticpanda
Jul 7, 2007
66
New York
that would be nice
that would be a good idea.. to be able to drag your own pins and make custom bookmarks. :laugh2:
alb0zf1n3st
Jul 2, 2007
624
Google has it when you Login and use maps you can save the pins and stuff.. I wish they could integrate something that would let you login and you have them saved or not even login since its you own iPhone
jvanlee1
Jul 17, 2007
29
Custom Map Locations
Search for the latitude/longitude coordinates. You will need to convert degrees-minutes-seconds to decimal degrees. South latitudes and west longitudes must be preceeded by a minus sign. If you need a decimal lat/long converter, go here: http://www.fcc.gov/mb/audio/bickel/DDDMMSS-decimal.html. I use Google Earth to get exact lat/long using the "add placemark" feature.
Try it by searching for 38.897661 -77.036567. This will put a pin right on the White House. Tap on the blue > next to the pin to add a bookmark, then edit the bookmark to put in your unique name for the spot.
BTW: map widget also allows searches by 3 and 4 letter airport identifier.
