Maps GPS?
joeg679
Jul 18, 2007
391
I live in NJ, but my friend typed in his home address, which is in Long Island, into my google maps. I was home today and typed in Sushi and it gave me sushi restaurants in Long Island. I was also in manhattan later and the same thing happened. Is there a way to set the phone to know where you are and give you results accordingly?
Alexander
Jun 28, 2007
1,724
Atlanta
If I'm searching for Starbucks in Atlanta, first I type "Atlanta, GA" then it zooms in on Atlanta, then I type "Starbucks" and it pinpoints Starbucks in Atlanta.
ChArLiE713
Jul 3, 2007
149
I type what I am looking for then I put the zipcode
alexster
Jul 15, 2007
There is no GPS device built into the iPhone. =/
You gotta tell it where you are
iPhobos
Jul 25, 2007
201
This is how I would suggest going about searching for something. I have used this method countless times and made it to my destination in a phlash
joeg679
Jul 18, 2007
391
Thanks, that is the best way to do it.
Martlet
Jul 11, 2007
145
The format is the same as google maps.
"Sushi near Manhattan, NY" or
"Sushi near 90210" or
"Sushi near 1600 Pennsylvania Ave, Washington, DC"
You can cheat, and iPhone Maps will guess what location you wanted if you just give it a search term.
If you type just "Sushi" iPhone Maps will guess this means "Sushi near <the last location I was at in maps>".
So, you either have to give it what you want to find, and where you want to find it, or navigate to where you want it to start searching, and then give it a term.
