May Have Bricked Phone
jeremymobile
Jun 30, 2007
98
So I really think I screwed things up. In the downgrading process I used ibrickr to reboot the phone after installin 1.1.2. Now it my phone is just running lines of code. It has done this for 20 min. Every once in a while it flashes to the Apple logo, and starts again. Please help:sick::sick::sick:
jeremymobile
Jun 30, 2007
98
I am craping my pants, please help. Tinman where are you?
phillyphill39
Dec 30, 2007
146
plug your phone into your computer hold the sleep button and the home button this will force the phone into restore mode. iTunes will notice that its in it and you will be able to restore your phone
Sep 7, 2007
most likely you'll have to force it into DFU mode, so while its plugged in do restart it by holding sleep and home while its running its endless code loop, then as soon as you see the Apple logo again hold sleep and home, yet as soon as it shuts off continue holding the home button. iTunes should now recognize it and you'll be able to restore.
jeremymobile
Jun 30, 2007
98
I have tried this 3 times and the screen just goes white then blue then purple.
phillyphill39
Dec 30, 2007
146
you sure you holding it long enough, because this has happened to my phone atleast 3 times and i get out of pretty fast. Is you phone unlocked?
jeremymobile
Jun 30, 2007
98
I don't really know. If I hold the sleep and home button i get the yellow triangle but before I can tell iTunes to update it, the code on the phone starts running and iTunes gives me an error 5
Sep 7, 2007
try and download the DFU file found here: http://www.modmyi.com/forums/showthread.php?t=25695
extract that and throw it anywhere in your c: drive (im assuming you're on windows). Then connect the iPhone, click start, then select run and type:
c:/dfu/dfu iBSS.m68ap.RELEASE.dfu
then click ok, this should send your phone into dfu mode and iTunes should be able to run a restore.
