Maybe a dumb question but
May 18, 2008
24
I am on o2 35 plan with 16g iPhone (maybe daft for signing up for the contract but should keep my bills down :) ) now my question is if i jailbreak my phone will it mess my contract up . I don't want to jailbreak and then find out i i cant use my phone without it blocking.
jptolife
Jul 15, 2007
645
New York City
Not going to affect anything on your contract. Jailbreak means that you'll be able to install third party apps on your phone, it has nothing to do with the service provider.
May 18, 2008
24
Thanks m8 , I will have a read now and find out how to do it :)
Is there anything i have to be aware of like connecting to iTunes or similar after jailbreaking
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
You should be fine connecting to iTunes just make sure that you do NOT choose to update the firmware without first doing a restore to factory settings. This can possibly mess up your iPhone and make it very bothersome to fix. Though, we won't have a new firmware until June at the earliest.
You should look at this thread. It explains the pros and cons of jailbreaking and how to do it.
- John
MaverickC17
Dec 29, 2007
178
Jailbreak
Wow...way to complicated for what it is.
Jailbreak=
1, Backup contacts & calendar with PC or MAC.
2, Update to 1.1.4 (stop iTunes from syncing when finished)
3, Close iTunes
4, Download ZiPhone 3.0
5, Select the "Jailbreak" button
6, 60 seconds later you are Jailbroken
7, Done...
