Maybe old question... (Google maps)
sled14
61
Fort Lauderdale
I was wondering, after you search for anything in Google maps, a bunch of pins come up showing results. How do you make them go away? Sometimes like 20 results will display and I haven't figured out how to get rid of them after
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
tap the search bar and then the X and they will clear. The qwerty keypad will pop up but if you tap the map in between the keypad and the search bar the clear map will come back without any of those annoying pins. :)
sled14
61
Fort Lauderdale
K got it, when I deleted what I typed and 'search' comes up, it takes the X away but the X stays when i leave the search word in it, if that makes sense. Thanks for the help!
