MacBook Pro MBP 16GB RAM Upgrade?
IllusionEntity
Jun 3, 2010
1,990
163
Borough Green, Kent, UK
Would it be worth upgrading my MBP to 16GB of RAM? It would be quite costly. So just wanted to know if I would see a DRAMATIC increase in speed and overall performance? I will be going from 4GB to 16GB on a 2.4GHz Quad-Core 2011 MBP.
15,385
1,023
I doubt it would be very dramatic. What kind of activities are you trying to speed up? What does your "system memory" tab in activity monitor look like when you do them? Screen shot would be good.
I've got 6GB memory on my mac, and rarely fall below 1GB of free memory unless I'm running a virtual machine AND encoding HD video or something crazy.
IllusionEntity
Jun 3, 2010
1,990
163
I am really only ever going to use it for anything other than browsing and downloading movies and watching them. I may in the future do some video editing if I decide to take up YouTube again. But what can I say. I'm greedy and impatient :p
iphonewarrior
13,847
699
To be honest if all you're going to be doing is browsing and downloading you'd be fine with 4Gb or even 8Gb of RAM. I've got 8Gb in my MBP, runs like a beast :)
IllusionEntity
Jun 3, 2010
1,990
163
2.4Ghz Dual-Core. My MBP is nearly one years old, it was purchased just before the new ones came out. I'm more than happy with it's power :)
Do you plan on upgrading? I mean I always like to get the new gadget but I don't feel that it would be that warranted with a MacBook. I mean I think I have the 2.2GHz quad-core. And plan on upgrading the RAM to either 8 or 16GB. What gives the MB the speed? The processor or the RAM? I'm not that good with computer specs :p
Lon
Jun 5, 2010
2,946
132
Alaska
How about an upgrade to 8GB? It is quite cheap. Worth it?
If you are intent on upgrading, I went from 2GB to 8GB on my Mac mini 2011 (2.3 GHz Dual-Core i5) for $45 US. That is more memory than most would ever need and the value is tough to beat. More memory than that gets really pricey.
IllusionEntity
Jun 3, 2010
1,990
163
See I'm looking at an 8GB upgrade as it is £37.95 in the UK. But a 16GB upgrade is £459.99.
I don't get why the prices soars for the extra 8GB more...?
Lon
Jun 5, 2010
2,946
132
Alaska
Neither do I. But it is what it is, and I don't see any substantial return for such a high price difference.
iphonewarrior
13,847
699
Dave, to be perfectly honest you're so indecisive it's untrue. For what you're going to be doing you don't even need to upgrade your RAM. But, if you want to upgrade then 8Gb's is more than enough. Trust me.
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
John is right. You'll see next to no increase in performance with everyday computing tasks with 16 gigs over 8 gigs. Save your money.
It goes back to the specs numbers fallacy. More is not always better.
