Memory issues, if i erase contents, will i need to re-jailbreak iPhone
Jan 19, 2009
i wrote this earlier but put bad title and lil confusing
ok, i have jailbroken iPhone with swap tunes installed. i had couple movies i wanted to delete but it wouldn't take the files off phone. don't know why.
I synced phone with movies and music unchecked and it deleted the movies, which is what i wanted. The problem now is it didn't free the memory off phone, i checked my settings and it still says only 2.4g available. which is what it said when i had all the movies on the phone.
ive tried turning off phone and resyncing and still nothing. still shows 11gb in use when really theres nothing there.
anyone know what i need to do?
if i reset settings and clear everything will i have to re-jailbreak phone.
15,385
1,089
depends by what you mean by "clear everything".
If you restore your phone in iTunes, yes, you will have to re-jailbreak.
Jan 19, 2009
in settings>general>reset theres a "erase all content and settings" option
