Menu icons dissappeared...
levin2k
Nov 24, 2007
I have the a problem... i added a few apps and my installer has disappeared. And when im using ibrickr, the ringtones, sounds, files functions work but it doesn't detect any of the applications i have installed (I was trying to delete some apps to get my installer back on the screen). So because the ibrickr application function doesn work i cant installed the scroll app either!
Can someone help? i just wnt to get my installer back on the screen since it allows me to delete unwanted apps.
Thanks!
levin2k
Nov 24, 2007
Thanks!
Can someone help me?
Is there a way to manually install the Dock app so that i can select the Installer app again?
Or is there another fix to this?
goobs22xx
Sep 16, 2007
250
None has had this problem?
What if i ran the apptapp installer again...?
there is a post about this at least once every two or three days.
i found that in about 20 seconds. if thats too much effort for you to click on, yes, you can install iBrikr and install the Dock application through it.
