Menu Shrinked
alansmith
Oct 23, 2011
27
Hi
for some strange reason the icons of my apps have shrinked, i want to change the size of the apps on the menu to what it should be
can anyone help?
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Can you take a picture and show us here? Also what type of iPhone do you have and on what iOS version?
A possible full restore will fix this.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I've seen this happen.
Do a hard reset. Hold the home and power button at the same time. Ignore the slide to power off. When you see the Apple symbol release both buttons. Wait one minute and poof like Apple magic all should be back to normal
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
I've never seen the icons become smaller in size. HMM!
alansmith
Oct 23, 2011
27
if i cold the menu button will that break my jail break?
alansmith
Oct 23, 2011
27
will this work?
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Only restoring will break your jailbreak. What they are telling you to do is a hard reset by holding your home and power button until it shuts off and then you see the Apple logo. Then you can let go. Tell us if this fixes your issue.
iphonewarrior
13,847
699
From the sounds of things you've installed something on your device e.g Shrink - This can make your icons smaller. Have you jailbroken from a previously jailbroken backup?
When you jailbreak and backup, the actual backup will save a few of your jailbroken settings, check which apps you have installed Cydia.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
I was thinking this as well. I have a Cydia tweak called Bigify that, in the settings, you can change the size of your apps to very big or very tiny.
iphonewarrior
13,847
699
Bigify is basically the free version of Shrink. I purchased Shrink when it first came out, sort of wish I'd have waited a little longer.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Ohh! Well, sadly I'm sticking with all free apps and tweaks. I may ask for a giftcard for my birthday and use that to go crazy in Cydia!
Anyways, back on topic. You have to be very careful when using a backup of Cydia apps! :)
But this doesn't seem like a big issue. It may just be a setting that your apps are tiny.
alansmith
Oct 23, 2011
27
i did have a app which has shrinked my background but ive tried to get the same app and change the background it still don't work
alansmith
Oct 23, 2011
27
whats the app called? do i need to add bigfy to the sources? as you might tell im novice when it comes to jailbreaking etc
