mic cutting out during call ipdone 4
grant15271
Mar 18, 2012
Hi all
I have a iPhone 4 model MC603b firmwear 5.1 (9b176) carrier giffgaff (02)
when making a call or reciving one the mic cut out after a few seconds or doesn't work at all. been told in a private shop that its sno good replacing mic due to it working at times it must be a softwear problem.
Thank you for any help given
i have searched the forum but cant find anything about this problem
jcmitchell5
Feb 19, 2010
602
57
Arkansas
If you call Apple, they will probably just tell you to reset the phone to stock settings and if that doesn't work then they may have you meet up with an Apple genius. I would try the reset on your computer and go from there.
AZIANAPPLE
Jun 6, 2012
181
9
Is the problem your carrier network? Have you tested with more calls to different numbers? Have you tried FaceTime calls?
