Mic/Speaker not working while on a call
tuila
Nov 4, 2007
Hi..the phone mic/speaker has stopped working..ie. I can't use the phone normally to take a call, have to use either the headset or the speaker function. It just went off suddenly...what could be the reason? tried reset..still not working! And yes, the phone rings fine..only the speaker does not work even while trying to play songs - only the headset works!
If, by reset, you mean restore, then I would take it to Apple. It's possible you just got a dud.
If you do not mean restore, then do that.
Jul 14, 2008
I also have same exactly same problem mic/speaker is not working when call is made or accepted the only way to listen is either plug in headset or use speaker mode.
@petalmom, You are great I have act upon your instructions while listening music and I have solved the problem..
Many Thanks
