Missed Calls?
showguy
Dec 2, 2007
769
Long Island, NY
This used to happen to me when I was using 3g. Since I gave up on 3g and use edge with wifi in my office I am fine. Keep in mind that if you stray out of your wifi area and edge kicks in you will not get calls if you are on safari or sending email. They will go straight to voice mail. 3G was supposed to fix this issue but the constant switching between 3g and edge was giving me the same problem.
dwp1975
Jul 4, 2007
561
45
Rockville, MD
So, no need to return the phone?
Zanthe
#apple
Aug 9, 2007
2,638
323
I'm getting "some" calls going straight to VM. The phone doesn't ring and the next thing I hear is an alert that there is a new VM. There is no "missed call" recorded. Not always but lately.
Sometimes I get a missed call + VM but when there is no missed call there is VM only.
Any other suggestions? And no nothing is turned off or on vibrate. Like I said it's an intermittent situation that started happening about a week or so ago.
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
Is "Manual" turned off in Do Not Disturb"? if not, turn it off.
Sent from my ancient but trustworthy iPhone 5. ☮
AT&T, right? This happened to me for years on several different iPhones and I was never able to fix it despite extensive troubleshooting. I don't think it's happened for over a year. I think it was just AT&T being unreliable.
If you want to try some troubleshooting, start with resetting your network settings. Test it for at least a week and then post back.
  • Like
Reactions: Zanthe
Zanthe
#apple
Aug 9, 2007
2,638
323
Yep. AT&T. Started about a week ago but mostly happened at home where reception isn 't great and working off AT&T micro Cell. I rebooted the Micro Cell a while ago and rebooted my phone (again). I might just try the Network settings restart but I think it's an AT&T thing being unreliable like you said.
Thanks for the suggestions.
