Missing apps
blsamuels
Mar 3, 2008
I have many apps installed on a jailbroken iPhone. The apps are still there but the launch icons are gone. Is there a way to get them back?
Mar 4, 2008
no reply, just want to subscribe to the thread
blsamuels
Mar 3, 2008
I tried rebooting but it didn't work. All the apps show up in uninstall but there is no launch icon.
p911pew
Feb 28, 2008
Northern Ireland
:mad:
This happened to me also
I just uninstalled all the apps and reinstalled
I am afraid it appears to be the only way to fix the problem!
I would advise you check to see what the Apple updates will add to your phone before updating in future as 1.1.4 does fick all:p
lalique
Mar 27, 2010
9
Why is it that when I unlocked my iPhone with blackra1n and installed rock some apps disappeared like the app store, contacts, compass, calculator, notes, mail, and calendar? Is there a way to get them back? I already tried "reset all settings" and "reset home screen layout" but still nothing.
Btw, this is a 3GS.
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
restore again :(
we do not provide the links to stock apps. i've checked and there actually aren't any. for the future make a copy of the stock apps via cyberduck or winscp :)
28,365
5,507
Can you open them with Spotlight? Maybe they are just hidden with SBSettings.
28,365
5,507
This might be worth a try before restoring:
Settings > General > Enable Restrictions > Disable Restrictions.
Also, try a hard reset. Press the home button and the power button at the same time for several seconds until it reboots (ignore the slide to power off).
lalique
Mar 27, 2010
9
If i do the hard reset will i have to unlock it again?
28,365
5,507
No. It just reboots it. It just takes a little bit longer than a standard reboot.
