Missing Apps?
Mi-Phone
Feb 4, 2012
80
Downgraded my 4s back to 5.0.1 so I could JB and everything was working great but then I started to use Infinifolder and now I have a lot of missing apps from a folder I made called Arcade (games and media) so I decided to remove infinifolder thinking that would fix it but it didn't. I then went to safe mode to uninstall some of the missing apps then went back to normal mode and reinstalled the apps but as I watched them install they disappeared as soon as it finished installing them. Any suggestions would be appreciated, thanks
Go to SBSettings > More > System Wide Options > Hide Icons > toggle on the apps if they are turned off. If that doesn't work, let me know if you can you access them through Spotlight.
