Missing dictation
Docd
Oct 16, 2011
651
66
My brother-in-law's iPhone 5 is missing the dictation microphone in the keyboard. I've looked under settings/general/keyboards but there is no switch to turn it on as on my 6+. Is this turned on anywhere else?
RoofMonkey
Jun 21, 2010
8,876
2,049
I think that Siri needs to be turned on for the mic on the keyboard to show. Double
Check that he has Siri active
Docd
Oct 16, 2011
651
66
I turn off Siri on my phone and the microphone is still there I my keyboard and so is the option to turn dictation on or off. So I don't think that's it. I believe it is turned on but I will have him check anyway.
28,365
5,506
Settings > General > Keyboard > English > Enable Dictation > On
If that was already on, is his keyboard set to English? Siri dictation doesn't recognize all languages.
RoofMonkey
Jun 21, 2010
8,876
2,049
He said there isn't an option like that, as far as turning it on. I don't see that either on my i5, but I'm on 7.x.x
RoofMonkey
Jun 21, 2010
8,876
2,049
Turned off Siri here:
Turned Siri back on here:
Don't know if it matters, but I'm iOS 7.0.4
Docd
Oct 16, 2011
651
66
Ok problem is solved. It was the fact that Siri somehow got turned off when he did the last update. Thanks for the help.
28,365
5,506
Just trying to cover all the bases. It's at the very bottom and I thought he may have missed it. It's an option on 8.x.
I can disable Siri and still use dictation. Are you certain it wasn't the dictation toggle? Do you see a toggle for it now?
Docd
Oct 16, 2011
651
66
I can too but it was Siri. Maybe if the upgrade turned off you can't use dictation but I don't know for sure. Most likely just a glitch in iOS.
RoofMonkey
Jun 21, 2010
8,876
2,049
NOW I see that this is in the iOS 8 folder.... Oops ;)
