MivTunes Alternative?
FTWrath
Jul 7, 2009
14
Is there an alternative to MivTunes?
I installed it for 3G 3.0 OS and it doesn't work.
After I activated it it says its already expired :/
Then I tried using a new account and now I can't get in it AT ALL.
Even if I try to add the same account as the first time it says that I can't use multiple accounts :/.
Any alternative?
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
Any alternative?
If you have used it (MiVTones) in the past and had created an account, once your trial expires on THAT iPhone, you're done. You need to purchase it then.
And for the record, it does work on OS 3.0.
FTWrath
Jul 7, 2009
14
Well like my post says, after I activated it, it wouldn't work.
As in right after I activated it. As in it had not been activated before.
Actually, it happens to be down. Their website isn't working or anything. Probably why the activation wasn't working.
