MMS apn?
Aaron
Jun 26, 2007
77
I got these settings from the tethering site and wondered how to enter them. For some reason when I try to do the command hack for iTunes it does not allow me to enter ipcc's
APN
: wap.cingular
User: wap@cingulargprs.com
Pw: CINGULAR1
MMSC: mmsc.cingular.com
Proxy: 66.209.11.32
guest03
Mar 30, 2009
80
Aaron
Jun 26, 2007
77
As of right now final 8.2 on xp. When I get home same only on OS X.
guest03
Mar 30, 2009
80
in order to load carrier files (ipcc) through iTunes it has to be the beta version of 8.2 pre-release.
the final was made so that you couldnt load custom ipcc files to your iPhone.
Aaron
Jun 26, 2007
77
any way to still get 8.2 beta and downgrade? Also does anyone know if I would have to do anything special with my att plan to get them to work.
BlindSpoTT
Dec 16, 2008
1,092
York, PA
My suggestion is to remove it from only one computer, install beta 4 iTunes on it and use that to update the ipcc. Would be best it it's not your main computer for your phone. That's how I got mine on. Then there is no moving of .itl files.
