MMS not working on iPhone 3G running v 3.1
Apr 1, 2009
MMS is not working. I'm running 3.1 on my 3g. not unlocked. What can I do?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
After you update your carrier file via iTunes, you need to reboot your phone. Try that, and let us know.
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
MMS is not working. Im running 3.1 on my 3g. not unlocked. What can I do?
Did your carrier file successfuly get updated through iTunes? It would have prompted you to do so if you were on 3.1. If not, you can do this manually. Let me know if you have done this. Also, check what version your carrier file is. Go into Settings > General > About - and check "Carrier" - ensure it is at least 5.x or 6.0.
Apr 1, 2009
I was on phone for an hour. I told them first to check equipment code bc i switched to 3g bout 6 months ago. First guy didn't. I then talked to the specialist, he updated my equipment code to 3g and voila, it worked.
