MMS Should work on AT&T
FrankieG889D
Mar 23, 2009
232
If you have the hacked ipcc file right?
FrankieG889D
Mar 23, 2009
232
yeah im saying it should work on the 3Gs if you already have the carrier hack on your 3.0 beta now...
iphun
Mar 16, 2009
1,967
PA
Just like Napoleon I have had it set up since march. As soon as you get the 3GS you will have the stock carrier file which is not supporting mms at this time. And if you want to add it you will have to get the first iTunes beta to add it. And then it all depends on if your account is set up to support it.
FrankieG889D
Mar 23, 2009
232
I have the 3.0 beta now with the hacked ipcc file, so as long as I have that file and an older version of iTunes, or at least the one before they stopped you from adding your own ipcc file, i can add it in when i sync my iPhone 3Gs to iTunes. This inturn will enable MMS and Tethering on my iPhone 3Gs, correct?
iphun
Mar 16, 2009
1,967
PA
OS 3.0 only works on iTunes 8.2 so you will need that first 8.2 released with beta 4. It should enable it unless they found out a way to lock it out with the new phone. They did say security and encryption was better on the new one(or maybe that was 3.0)
FrankieG889D
Mar 23, 2009
232
Yeah i have everything that i should need.. i was just trying that it should say that if you have mms on the 3g you should be able to get in on the 3Gs.
shutter13
Jan 8, 2009
2,208
153
Since no one has a 3G S we can't say for sure it will sync with the first prerelease iTunes, I suspect it will, but until someone gets their hands on the phone and tries it...it's just speculation.
