Mobilechat for 1.1.3
Inverted
Feb 17, 2008
156
is it on installer by any chance?
Spaniard85
Nov 27, 2007
40
Looks awesome, but it doesn't look like it's on Installer yet. I've still got 2.0.0b showing up. :(
IphoneTony
Nov 10, 2007
2,163
New Jersey
see that is something I could use... cut my cell plan down with the texts and just use the $20 package... 200 texts per month and just aim everyone that using it also
overbo0st2k4
Oct 17, 2007
264
whats a good program for PC to install apps on the iPhone, such as this one?
I tried ibrickr v0.91, the MobileChat app is not a PXL and I'm not sure hot to upload the file folder itself...
overbo0st2k4
Oct 17, 2007
264
How about an easier fix until its hosted by Conceited on Installer?
Use this TEMPORARY Installer Source:
http://twenty08.com/installer
Then find MobileChat under the "twenty08" category.
Enjoy!
"While we wait for Conceited to update MobileChat in their repository, we’ve gone ahead and created a temporary one for everyone so they can finally use MobileChat 2.1 and get us feedback.
This is definitely only a temporary solution, and we’ll be getting 2.1 on Conceited as soon as possible."
Inverted
Feb 17, 2008
156
how long does it take to update once you install the source, i don't see twenty08.....
overbo0st2k4
Oct 17, 2007
264
once you had the source exactly like this"
It should refresh after it is added. You could try force reloading again by simply pressing the "reload" button at the top of the source tab in installer.
Then head over to:
"Install > twenty08 > MobileChat"
Good luck!
Inverted
Feb 17, 2008
156
got it! i wish there was a gtalk on there but oh well .aim is good enough for now!
overbo0st2k4
Oct 17, 2007
264
The developer is working on gtalk and it is supposedly going to be in the next version of MobileChat :)
lman
Oct 18, 2007
632
great app, like it a lot more then apollo. Feels a lot more stable...
Then head over to:
Good luck!
It worked!
Only problem I see is when someone sends a message in bold it shows up " <B>nice</B> "
got_phi
Mar 19, 2008
does this work on unlocked iPhones for tmobile?
