MobileMe calendar entries
llckll
Feb 18, 2009
154
Hello,
My mobileme calendar entries are not syncing to my outlook 2007. Any ideas what's going on? The mobileme preference center is up and running.
Thanks.
shutter13
Jan 8, 2009
2,208
153
In the mobileme control panel under the sync tab is it:
1) set to sync calendar with outlook?
2) set to sync automatically?
llckll
Feb 18, 2009
154
Everything was set up correctly. I didn't realize that outlook 2007 doesn't merge entries into one calendar. You have separate calendars for each. So I know have two separate calendars side by side which is kind of gay.
shutter13
Jan 8, 2009
2,208
153
I think, before I set up mobile me...I ended up with two calendars in outlook, I deleted one of them, so I didn't have that problem when I set up mobileme.
PDACPA
Jan 16, 2008
542
If you set up multiple calendars in mm, when you ole Outlook 2007, go to the left panel and put a check mark in each of the calendars. You will see each calendar side by side. Get too many and they display sideways. I tend to use the mm web app with safari to view my calendar and outlook just alerts me to the alarms.
