MobileMe--Calendars and bookmarks working for anyone?
NateEssex
Jun 30, 2007
306
NJ
I have my mail, I think, working.
I went on my MBP and did the system pref sync and it all appears correct in iCal and Address Book.
The problem is I'm not getting Bookmarks or Calendars "pushed" to my iPhone 3G.
Any ideas?
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
did you go in to the system prefes and go into .mac/mobile me and in they sync tab hit sync automatically?
dcom
Aug 7, 2007
1,421
Suwanee, GA
Syncing automatically will only sync if you manually connect to the internet and will do it next time you connect after adding a calendar entry. If you're continuously connected to the net (like with DSL or cable), Automatic syncing defaults to hourly. This is according to the Help on my MBP.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
i added the sync button to the task bar, and when i make a change to cal or contacts, i just hi the sync button....
my mail is still not pushing... that is annoying
