mod 1.1.3
Popdevil
Jul 2, 2007
254
I used to have my phone moded but restored to factory settings. I can't live with out the text message custom sounds anymore. Is there software out there for 1.1.3? I know there is for 1.1.2
KNK
Jul 22, 2007
2,391
Stevenson Ranch
No 1.1.3 yet, but there has been rumors over the past couple of weeks.
termleech
Sep 7, 2007
1,154
McPherson, KS
I think you are a bit confused. There is no 1.1.3 firmware out yet, so I'm assuming you are running 1.1.2?
Popdevil
Jul 2, 2007
254
DOH! Yes I was so wrong. I do have 1.1.2 - I guess I did it mixed-up with the update coming out of 1.1.3.
..off to mod my 1.1.2 now.
Boosted_Brian
Oct 30, 2007
64
Ummm I was able to make custom sounds for all my texting, voice mail everything... But I also use Adobe audition to edit my sounds and can covert right to the .aif format which is used for everything but the ringtones. There is a section in customize that will allow you to change these sounds once you load your custom made files into the correct folder.
Wow, this thread confused me. I was half down to iTunes ready to click "Check For Update". That's just what we need right now. Seriously. :p
- John
