MOD Your Passcode Keypad Color
Alexander
Jun 28, 2007
1,724
Atlanta
HERE is the Keypad Colors
For every one who has a Passcode to unlock their iPhone (which you should!), this will change the color of the keypad when each button is pressed.
System/Library/CoreServices/SpringBoard.app/DeviceLockKeypadPressed.png
_________________________________________________
If you'd rather have the Keypad color changed before pressing the buttons navigate here
System/Library/CoreServices/SpringBoard.app/DeviceLockKeypad.png
HERE is the Keypad Colors, I'll take requests too.
victo019
Jun 14, 2007
Can you point me in the direction to even start the color and icon changes? I have done the ringtone thing so I have jailbreak and the iPhoneinterface. I am using win xp and just need a link to the instructions. Thanks.
Alexander
Jun 28, 2007
1,724
Atlanta
Well first I suggest this
http://forums.everythingicafe.com/threads/drag-and-drop-program-for-modding.5605/
Just extract those files into your jailbreak folder, and then run it. It allows you to drag and drop your fies into your iPhone instead of using command prompt.
Second, you have to understand that we are simply taking image files and REPLACING them over the ones that come default on the iPhone. Every image file is located somewhere different in the iPhone's directory.
Once you find an image file you want to add to the iPhone, the easiest way to find what directory it belongs in is to go here:
http://www.modmyi.com/wiki/index.php/iPhone_file_and_directory_list
Press CTRL + F, and search for the image file name.
AllanGT
Jul 2, 2007
71
Dallas
I like the red one a lot, is there a way to make it a little bit more transparent? The red is a little heavy, but it matches my theme perfectly if it could be just a bit more transparent :)
Also, do you have the stock keypad file?
ojasray
Jul 17, 2007
22
sounds good, can you just post a image or screen shot of your iPhone so i know what your talking about....
Alexander
Jun 28, 2007
1,724
Atlanta
Has there been any luck with the phone keyboard?
For some reason the Phone Keyboard will NOT change. I putfile and modify what seems to be the correct directories - or the only ones visible - but I never have any luck. The folks over at modmyiPhone got the same results as me.
psychoticpanda
Jul 7, 2007
66
New York
IT DOES WORK
if you hold down the key when your typing in the code you should see the color. it only works when you hold it down. its not the color of the keypad its self.
Alexander
Jun 28, 2007
1,724
Atlanta
IT DOES WORK
I'm aware the CODE keypad works, I made this thread. However, he was inquiring about the PHONE keypad - as in the keypad in which you dial numbers on. Which by the way, is not working.
Alpha Zero
Jul 21, 2007
So can we just add the picture that Alexander added in the directory mentioned on that thread?
No, I'm not sure. Check that thread, I think they've gotten it. I don't really have much interest in changing my dialerpad so I didn't really read the page.
BTW, Alexander is it possible for you to make a darker blue? I suck at PS and I've been trying to make it darker, but it doesn't quite come out right. I have the dank blue color change set and need a darker blue keypad to go with it. Like the "bluebattery" blue. Thanks.
sykl1
Jul 24, 2007
ive been able to change the "Call" button on the phone dialer to red, and also changed the delete and add contact button to turn red when theyre pressed.
Alexander
Jun 28, 2007
1,724
Atlanta
Yes, I'll get it up after dinner. :laugh2:
