Modded 1.1.2 phone Installed 1.1.3 Problem
jeremymobile
Jun 30, 2007
98
I had a modded 1.1.2 and a lot of programs. I updated iTunes and the did a restore with update. The only thing that went wrong was I had no voicemail. If you pressed the VM icon it did nothing, like the vm software was not installed. After restoring again, resetting, powering on and off, I called AT&T. The voicemail feature had to be removed from my account and put back on. I don't know if this was a direct effect of the 1.1.2 mod or what, but just incase someone else has this happen to them.
PLEASE HACK 1.1.3:cool:
mflantin
Nov 29, 2007
100
Has anyone else had any other problems after updating their phone to 1.1.3? I have a modded phone as well and want to make sure nothing gets screwed up.
C
Chez10
Guest
nothing should get messed up
ZipZap
Dec 15, 2007
529
I would think one needs to revirginize in all cases to play it safe
C
Chez10
Guest
On the installer app "re-virgin" Why does it say to make sure you know what you are doing?
SoleAddict23
Sep 16, 2007
46
whats re-virginize? how and what does it do?
ZipZap
Dec 15, 2007
529
The term re-virginize means bringing your iPhone back to its out of box state before upgrading.
I would say that you should restore you iPhone to the revision that came with it. So if your phone came with 1.1.2 restore that revision before going to 1.1.3
Going from a jailbroken operating system directly to 1.1.3 is not wise.
Also, as has been stated here many times on other threads, do not install 1.1.3 if you still want to jailbreak the iPhone. Jailbreak does not currently work for 1.1.3. Alo be aware that once you upgrade to 1.1.3 you cannot fall back to an older revision.
