Modded Customize
jjsquizz
Nov 10, 2007
252
Los Angeles
I don't know if you guys have found one, but I might have the solut6ion to your Customize problems. I tried it and it works fine. You still might have to use the 1.1.4 patch to install it http_://_www. _dlubbat.com/iPhone.xml (remove dashes), but I don't think you will mind. Happy Customizing! :laugh2::laugh2:
BD997
Dec 23, 2007
154
Boston, MA
whats the difference between this one and the other customize?
jUeLz23
Sep 4, 2007
350
i still don't see it. and added the source under what catergory is is under?
jjsquizz
Nov 10, 2007
252
Los Angeles
If you have the other one and it works, fine, but this was modified to work on 1.1.3, no problems. You still have to use the 1.1.4 patch, but it works.
meltd0wn
Feb 23, 2008
31
i have been trying to get this version all afternoon but cant seem to download it did they take it off line?
BD997
Dec 23, 2007
154
Boston, MA
where is 1.1.4 patch?
paa79594
Jul 23, 2007
547
Los Angeles
www.theplasticguys.com
I am trying to install ishare via fight club but all it tells me is i need ishare to install ishare.. im on 1.1.4 and haven't really done much and have been out of the JB scene since 1.1.3. am i missing something?
x999x
Aug 6, 2007
1,656
Hi, I'm not hosting the actual application, but rather, a fix for 1.1.4 which re-enables your preferences to save correctly again.
This is why I check first, and prompt the user to Install iShare first if it's not found already on your iPhone. If you notice at the end of the prompt I let you know which Category to find said application :)
In your case, head over to the Network category in Installer first, and install iShare. If you find it inconvenient in having to enter in your username and password each time you launch iShare, then you would proceed to install my patch to remedy that issue :)
merlconn13
Jul 19, 2007
52
i got customize to work but when i change anything on in the program (ex: battery ) it dosent change it. am i doing something wrong after i select it. this happened to me when i hax 1.1.3 as well im on 1.1.4 now
CBRfanatic
Feb 28, 2008
302
Bronx
Look in installer under either "Tweaks(1.1.4) or Fight Club, called "TWK: 1.1.3x4 swap"
you can alway log in via SSH and go to /system/library/coreservices open the systempreferences.plist and change the 1.1.4 to 1.1.3 restart and now any program you install or operate will think you are running 1.1.3
do it again to go back to 1.1.4
connie
Jul 11, 2007
2,839
105
So Cal
Welcome to my world! I have the same problem and it's frustrating. I still haven't been able to figure out the whole SSH/Wnscp thing.:(
Doakiphone
Feb 26, 2008
41
Hey guys go easy, I just jailbreaked for the first time last night and have been trying to figure out how to get customize to work. Can someone walk me through it? I can't find the fight club thing or the tweak thing mentioned in this thread. I really wanna customize like a mug. Also is there a fix for pocketguitar (i searched and couldnt find anything, i really want that to work) thanks.
meltd0wn
Feb 23, 2008
31
is there a new source for customize if so wanna help a brother out if possible
many thanks
meltd0wn
Doakiphone
Feb 26, 2008
41
For all those trying to install customize check out this great video on youtube. It worked for me.
djentee
Sep 17, 2007
24
I followed every second of the video adding the 2 sources:
1. http://repo.ispazio.net
2. http://ipodtouch.net/repo.xml
I installed the 1.1.4 Compatibility Patch. I've refresed 3x already looking for "customize 1.1.4" but nothing. Only the regular customize and customize old under the "All Packages". What am I doing wrong?
Please help.....
BD997
Dec 23, 2007
154
Boston, MA
