Modding lock screen
Sep 7, 2007
23
This is my fourth post, and so far I have had no help... Where is everyone? Does anyone know the png file I need to delete to remove the top transparent bar on which the clock is shown in the lock screen? I want a clear view of my wallpaper...
Sep 7, 2007
23
I have no idea why you pointed me to the sticky, but still cudnt get the png for the top bar of the lock screen... Can you just tell me the png and its path for the top bar?
seb481
Aug 3, 2007
774
San Diego
I'd like to find out how to remove that too. I can't seem to find this image in system/library/frameworks/telephonyui.framework
Any help would be appreciated
seb481
Aug 3, 2007
774
San Diego
What does that mean? There are a few of us out here who would like to remove that .png file.
It means he's posting so this thread goes to the top of the forum, thus having more chances to find an answer
matt3224
Aug 4, 2009
find a fix
Did you ever find out what the file is ? I'm trying to work it out and have been stuck for 2 days now it's driving me mental.
iNinja
Aug 8, 2008
3,984
20
UK
You have to options, just download from Cydia Transparent Status bar and put it at the top of your winterboard selections. I think its still available. If its not, use the manual process below.
I have attached the files that you can manually rename and ssh into your phone..
Here you go. Just rename the files in archive -
and put them in
System/Library/CoreServices/Springboard.app/...
Or, just download from Cydia Transparent Status bar and put it at the top of your winterboard selections. I think its still available. If its not, use the manual process below.
I don't think he's talking about the status bar. Iif you're looking to remove the bar that resides behind the clock, it's called UILCDBackground.png. You can easily theme it via WinterBoard. Download the file I've attached, unzip it, and drop the theme into /Library/Themes on your iPhone. Then activate it WinterBoard. Done.
matt3224
Aug 4, 2009
Cheers
Thank you guys so much. If you want to check out my theme it's called iMattic and it's in the themes springboard section. thanks again
Dec 10, 2010
11
what about the " introduce your code " bar? i have like 4 hrs using transparent icones everywhere trying to hide it and i just cant make it . :(
mazen222
Feb 20, 2011
I don't think he's talking about the status bar. Iif you're looking to remove the bar that resides behind the clock, it's called UILCDBackground.png. You can easily theme it via WinterBoard. Download the file I've attached, unzip it, and drop the theme into /Library/Themes on your iPhone. Then activate it WinterBoard. Done.[/QUOTE
Thank youuu! Finally!
Faheem
Oct 24, 2011
does it work on IOS 5 as well? because ive tried n i cant get it to work n e help?
iphonewarrior
13,847
701
Certain modifications don't work with iOS, yet. The themes/mods will eventually be ported over so they can be applied again soon.
