mods 101
Dec 13, 2007
25
utah
I am new here, and to "modding" my iPhone and I really appreciate how nice and helpful people are here. I have seen some really good informative posts about how to "jail break" the iPhone. but I have not been able to find any posts on the next steps after that. i would like to learn how to add or change themes other than through the installer. I have been able to connect through a ftp client but I do not know where to put specific files. for example I downloaded a file for a theme from this forum, and it is a ".artwork" extension. but I have no Idea how to put that on my phone. Thanks for your help in advance. any info will help.
thanks
Chris716
Nov 29, 2007
807
IL
you need to install program called summerboard and like customize then add some themes which can be added from installer as well
Chris716
Nov 29, 2007
807
IL
i haven't used those in awhle but im sure it has to be put in your phone through ssh search ssh and you should find something...
