MOD's to the top bar on iPhone
ptnubs
Nov 28, 2007
I have seen a few iPhones where the top bar, where it says AT&T, has been modified to say whatever the owner wants, instead of the AT&T thing.
How are they doing this?
15,384
1,089
first you have to jailbreak your iPhone to get read/write access to the file system. Then either manually edit the image files, or use an app like "customize" that provides a GUI to help you do it.
iAttorney
Sep 30, 2007
90
Houston, TX
if you just want to edit carrier text (not an image) then I would use an app called "Make it Mine." It is super easy to use and it works on 1.1.4.
Hope it helps!
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
After you jailbreak install StatusStyle, which is on the Installer. It's simple and works great. :cool:
