Mountain Lion
lemoon
Oct 28, 2010
216
11
Have just read the features of Mountain Lion on Apple site, I just have to say, I'm so excited for Mountain Lion.
http://www.apple.com/macosx/mountain-lion/features.html
Have downloaded it iMessage for Mac today. Sweet so far. Conversations are showing up on iMac, iPhone, and iPad! NICE! And would test if the AirPlay Mirroring works well, hope I need to do less converting with iFunia, just "stream what’s on your Mac to your HDTV via Apple TV" on the go!
Hey guys, how about do you think about the Mountain Lion.
Here's another option: you can use the Air Video app to stream what's on your Mac to your Apple TV without converting. It does a live conversion. The iDevice is the middle man. It works great. I haven't had to waste time converting media in Handbrake for quite a while (last Spring, I think) because of this app.
craiggiarc
Jan 20, 2009
421
32
You can also stream without converting files if you Jailbreak your Apple TV and install XBMC Media Center on it.
Christopher Meinck
Administrator
Administrator
Sep 13, 2008
89
23
Is it too much to ask for Safari to be improved? I consistently find myself logged out of sites and then there is the dreaded "refresh" when moving between open windows. Drives me absolute nuts.
iphonewarrior
13,847
699
Use Chrome. I moved from Safari because of the relentless amounts of bugs, seems it's still not polished.
Vorsos
Mar 3, 2012
I think the refresh bug is a symptom of Lion's memory management, where instead of paging an app's active memory to disk, running apps are dynamically deallocated of RAM in safe areas. In this case, Safari's core code remains active, but pages are unloaded from memory, iOS style.
I experience this often enough, since I usually have two Safari windows full of tabs, as well as a dozen other apps running.
This doesn't make the issue any less annoying per se, but is perhaps better than not knowing why. Maybe a future version of Safari will refrain from unloading pages that have current login cookies or active form fields.
lemoon
Oct 28, 2010
216
11
Yes, just use the Chrome.
Chrome works fine for me, and very fast to load pages~
