Movies not found
dobymax
Oct 19, 2007
238
Took your advice on moving my movies over from my desktop....worked like a charm. Thanks. One more problem. I have three movies that are checked where the iPhone updates but won't copy. When I go into iTunes and click on them, they say that the movie can't be located. Can someone tell me where it is or is it even recoverable? Thanks guys.
showguy
Dec 2, 2007
769
Long Island, NY
It sounds like these movies may not be in a compatible format for iTunes or the iPhone. Even if they are not compatiable you will see them checked off in iTunes, however they will not install.
