Movies not syncing over to iPhone
lost
Jul 23, 2007
When I sync 2 movies to my iPhone, iTunes shows the 2 movies copying over, but when I look at my iPhone only one has copied over. The capacity bar in iTunes shows the file sizes saved to the phone correctly. One just doesn't show up on the phone. I've tried different movie files, restarting the computer and phone. Nothing is helping. Does anyone have any suggestions?
mrmacbook
Jun 13, 2007
139
my only guess would be what kind of movie files where they?
I think (not sure) they have to be .m4v to play on the iPhone. If one file was .m4v and the other was a different file type, it may not have copied over.
lost
Jul 23, 2007
Figured it out
All my files are mp4. The problem was, this is going to sound stupid, I had so many applications running on my computer at the time iTunes just didn't get everything copied over to my iPhone. I shut everything down and it synced up fine after that.
Thanks for all your responses!
