movies now show chapters
ArtGuy
Jun 4, 2007
51
Beantown, USA
When playing a movie ripped from dvd, the chapters now appear on the control panel - you can skip ahead/back by chapter using the forward/backward controller buttons! Yay! Haven't found anything else yet - but still looking!
(I'm referring to the 1.0.2 update here of course!)
x999x
Aug 6, 2007
1,656
I'm on 1.0.1 and my movies have always shown chapters. The only movies I have which contain chapters are the ones I got from iTunes.
hexonxonx
here's a really noobie question. How do u get movies on to the iPhone?
First you have to either have purchased some movies with iTunes or converted a DVD to your computer using handbrake or some other program.
If you buy the movies in iTunes, they will already show up in iTunes and all you have to do is choose to sync them to the iPhone.
If you have a movie that you ripped from a DVD using handbrake or another program, simply drag the movie into iTunes and it will add it to the movies tab. Place a check mark next to the movies you want to sync to the iPhone and press the sync button in iTunes.
The movies will show up in the iPod under the videos tab at the bottom.
iPhone always remembers where you left off while watching a movie so that you can continue at a later time.
RichardRahl
Aug 21, 2007
QUOTE=hexonxonx;83210]First you have to either have purchased some movies with iTunes or converted a DVD to your computer using handbrake or some other program.
iPhone always remembers where you left off while watching a movie so that you can continue at a later time.[/QUOTE]
Thank you, ive been doing some reading on the forums and elsewhere seems that there are many programss out there. Guess just have to do some researh
Thank you again for your help
