Movies & TV Shows won't add to iTunes?
trendyish
Jan 5, 2008
Kentucky
Hello, I am trying to get some movies and TV shows from my computer onto my iPod touch, I have converted them to mpg4 format. Whenever I drag the file over to my iTunes 'Movies' folder, nothing happens, the movie doesn't show up on the list nor on my iPod. I also went to 'File > Add File to Library' and the same thing happens, nothing shows up.
I've been messing with this for 2 whole days and I'm so fed up with it.
Can someone please help me?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You need to import them in using the upper left menus at the top.
trendyish
Jan 5, 2008
Kentucky
So was it a DVD movie converted with this AoA, I am not familiar with that converter. But I am sure there lies the problem, iTunes does not like the file.
It was an .avi movie that I downloaded offline.
I'm not sure which converter to go with, I've Googled so many terms and still can't find a free converter to use.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
I am on a PC (Vista). Yes I have QT pro, it was installed when I installed iTunes.
FantaSric...just open QT pro, open the avi movie, click export then you will see the preset for iPhone that is all there is to it. That will work.
I just reread, your post about iTunes, I bet your QT is just standard, you need the PRO which is $29...sorry
trendyish
Jan 5, 2008
Kentucky
Yes I had the Basic one :eek: I upgraded to Pro and I exported a video, it took 3-4 hours to do and there is just sound with some weird noise and no picture on QT and my iPod. What would the problem be there?
It did add to my iPod and into iTunes though (finally). Thank you.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Did you try the free videora software, that should only take maybe an hour. Also just test a small portion of a movie and try importing to make sure it works.
trendyish
Jan 5, 2008
Kentucky
I just tried Videora last night, I converted a movie and then I tried to import it in iTunes and it didn't show up on my movies list.
