Multiple downloads
iphonewarrior
13,847
699
I have seen it download and install multiple apps at once. Maybe its based on connection speed? I see you only have 1 bar on your wifi.
I've witnessed another app downloading while another apps installing. To be honest, I've never really paid any attention to how many apps download at once. :D
jcmitchell5
Feb 19, 2010
602
57
Arkansas
I have noticed that it will download simultaneous on my phone every once in a while. Maybe it depends on the size of the apps being downloaded.
RoofMonkey
Jun 21, 2010
8,921
1,983
Poking around the net, most of the references to this were from June. Most appear to be from the 14th to the 21st. Guess this feature didn't make it out of Beta, or could it be busy servers preventing it. ?
Ffmaster1
Oct 8, 2011
133
I really don't know anymore. :/ i remember when i was syncing apps after ios 5 update it was syncing multiply...
chazm
May 1, 2008
729
40
Wouldn't it be better to DL one at a time? Single apps will DL faster than DL all at once. IMO
iphonewarrior
13,847
699
Syncing more than one app and downloading more than one at once is two different things. iTunes may look as if it's syncing multiple apps at once but it doesn't. iTunes queues up the apps then syncs them one by one as it does with all media. You may see the icons on your Springboard, but you can't launch them until they render (non-transparent).
The simultaneous downloading off applications isn't really a show stopping feature, IMO.
iphonewarrior
13,847
699
I agree. Launching iTunes on your desktop/laptop and updating your apps on your computer shows you how slow simultaneous downloads are, even with a fast connection. Apps downloaded one at a time appear to download quicker.
