Music gone from phone/won't resync
bballrob
Oct 11, 2009
1,925
478
Alaska
Something happened the other day and when I did a sync all my music was deleted from my phone. I have it set up to just sync a few playlists and genres, about 500 songs. For some reason, no matter what I try, it won't reinstall the music on my phone. Any ideas? I can't stand the thought of going for a run tonight with no music!
Sent using iCafe app
5,578
Make sure "sync music" box is checked under the music tab.
bballrob
Oct 11, 2009
1,925
478
Alaska
Nope, not that. I've tried unchecking everything on the music tab, resyncing, then re-checking the items I want synced and syncing again. That doesn't help either.
5,578
As a last resort, you could rebuild the library, but there are some other things to try first. I'd test manually managing the music to see if that works. Also make a new playlist with a song that isn't in your current playlist and try to sync it. A corrupt file might be causing it. Do a hard reset first, make sure sync only checked items is checked and update iTunes if it's not the current version. What 4S firmware version are you using and is it jailbroken?
bballrob
Oct 11, 2009
1,925
478
Alaska
JB, yes.
iOS 6.1.1(10B145)
iTunes version 11.0.5
I've tried some manual management with no luck.
bballrob
Oct 11, 2009
1,925
478
Alaska
Ok, Europa, are you Jesus' sister, cause I swear you are my savior every time I run into problems here.
The sync only checked songs and videos was unchecked. I don't recall in checking it, but that doesn't mean I didn't. Anyhow, it is currently loading 1413 songs back onto my phone. So it likes I should be in good shape to go run 5 miles here in an hour or so.
5,578
Cool. I'm glad that worked.
Have a good run! :)
