Music is broken after jailbreaking iOS 5
macscac
Jun 17, 2009
464
Jail broke last night with windows version of absynthe
iPhone 4s with 5.0.1
Now when I go into music and pick any song it will play that song fine
When that's over and it goes to the next song, it won't play
I can pause and hit play but it won't move past 0:00
I have to close music and double hit home and actually kill the process and restart
Then it will happen next song
What the heck?
Reboot and sync if you haven't already. If that doesn't work, unsnc and resync your music.
macscac
Jun 17, 2009
464
seems to be working now.
i removed all music and resync'd it like you said.
thanks europa!
Jarred
Nov 13, 2011
133
52
Sweet, I've had the same issue. Will give this a go, was almost about to unjailbreak!
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Odd, removal and reinstallation as Europa suggested worked for me.
Maybe try restoring, removing all media and rejailbreaking, since the absinthe is so easy....
Jarred
Nov 13, 2011
133
52
Yeah, not too worried, have restored and its part way through syncing 161 apps across from its backup :sleep:
Wasn't a big user of the jailbreak anyway, just some minor tweaks here and there. I will miss the "Slide if you like Boobs" message on the lockscreen the most :LOL:
