Music on iPhone....
ghost28
Sep 30, 2007
Hey all, i just got an unlocked iPhone and was just wondering what version of iTunes should i be using to sync with the phone. thanks.
Zackram
Oct 5, 2007
You can use 7.3 or later, if you go directly to Apple they will have the latest iTunes software for download free of charge
iAttorney
Sep 30, 2007
90
Houston, TX
I would do some searching and double check. When I was originally trying to jailbreak/unlock my phone (before I gave in to the dark side that is AT&T) it was a requisite that you did not use anything higher than 7.3.2 I think. At any rate, check these forums and the other infinite amount of info on unlocked iPhones. I assume it will all relate to the method that was used to unlock your phone. With all of the quasi-bricking going on, I would hate to see you lose your phone.
