My daughter forgot her passcode!
Mariouk
Sep 8, 2010
239
Whilst messing around with her brother she changed the passcode several times to stop him getting into it! Problem is she has forgot the passcode! Will i have to restore if she doesn't by some miracle remember it? Is there a way around restoring?
offroadhunter
Apr 1, 2009
682
22
New York
You can try this:
Plug in your iPod
Go to "My Computer"
Open your iPod's drive
Make sure you can see all hidden folders (If you aren't sure go to Tools, Folder Options, View Tab, and check Show)
Open the folder "iPod_Control"
Open the folder called "Device"
Rename the file "_locked" to "_unlocked"
Gabey8
Apr 22, 2011
Does a device have to be jailbroken to see these things? On my non-jailbroken Touch on Windows 7, I click on the iPod in My Computer, and see Internal Storage, but when I click on that, I only see the DCIM folder where my photos are.
Mariouk
Sep 8, 2010
239
You can try this:
Plug in your iPod
Go to "My Computer"
Any instructions to do this on mac?
bballrob
Oct 11, 2009
1,930
479
Alaska
If you restore from a backup to fix this, wouldn't it restore the passcode you have forgotten as well?
Mariouk
Sep 8, 2010
239
Done a complete restore and rejailbreak, i haven't told her its fixed yet i wanna teach her a lesson! I told her to stop changing the passcode but she wouldn't listen! 8 goin on 28!
Sue Katich
Mar 15, 2013
My daughter forgot the password on her iPhone 4s, does anyone know how I can unlock it without losing all of her pictures and contacts. Please help.
MoneyMaker79
Dec 15, 2008
5,386
340
29
Pensacola, FL
Hello. Has a backup been made through iTunes? Contacts will usually be saved in a backup. The only way to fix this rather than going through Apple or a authorized retail store is restoring through iTunes.
If you're not able to restore without entering password, follow these instructions.
"To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black.
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!"
http://m.iclarified.com/entry/index.php?enid=1034
Sent using iCafe app
Sue Katich
Mar 15, 2013
I tried to restore from iTunes and it kept requesting a passcode. I am not real familiar with Apple products so I'm feeling a little helpless. Thanks for your help.
MoneyMaker79
Dec 15, 2008
5,386
340
29
Pensacola, FL
If you do the instructions in my last post, this will put your iPhone into DFU mode (Device Firmware Upgrade) which for iTunes will see the device in recovery mode and allow you to restore.
Sue Katich
Mar 15, 2013
I just got each of my three kids the iPhone 4s last month. I set them all up on my computer and downloaded music for them and did a sync. I believe they are also set up on the cloud. I'm not real sure if there was a backup done, unless it automatically backs up when you sync.
MoneyMaker79
Dec 15, 2008
5,386
340
29
Pensacola, FL
Before it syncs it does a backup. :)
