My earphones are not getting properly inserted into earjack
Sravanikishore
Oct 31, 2011
104
When i insert my earphones into the ear jack they are not getting completely inserted. What the do you think? When I insert the earphones into other iPhone or iPod they are getting inserted whats the problem. Please help.
Leo
Nov 9, 2008
901
137
43
32
Calgary, AB
Very hard to understand you.
Anyways, there is probably something stuck in your headphone jack. Grab a flashlight and peer inside, see if you see anything like lint or a small rock, etc...
voxnbass
Mar 25, 2012
9
Could it be the case you are using? I know my case stops the aux jack in my car from going all the way in, but not my earphones.
mgiara
Apr 24, 2012
If there is something lodged in the jack, I'm sure you can find a kit on cheapBay for replacing it.
I just did it for the screen.
bilkal828
Apr 7, 2012
11
Gently swirl a toothpick around the inside of the jack opening. Then put one drop of isopropyl alcohol in the opening. Let it sit for a second then blow it put with your mouth or a canister of compressed air. That should clear/clean out the opening.
Mine gets clogged with lint all the time.
