My eBay
lucky8926
Jun 16, 2007
217
Central IL
I installed the My Ebay app from installer but I can't find anywhere that explains how to set it up.... I have the token and widget on my mac, but how do I get the info to my phone?
420greg
Jun 26, 2007
845
Orlando, Florida
On your Mac:
1. Install and register the widget "eBay Watcher" on your mac.
2. Run Applications/Utilities/Keychain Access on your Mac and select the item eBayWacher
3. Your token is the entire entry in "Show password" field
On iPhone:
1. Install My Ebay via Installer.app
2. Install OpenSSH (if you have not already done so)
3. SSH into your iPhone
4. Type: vim /Applications/My\ eBay.app\Data.plist
5. Find the key for Token and place the token from your Mac's widget in there (if you have never used vim, press i to insert before typing, then press ESC when you are done).
6. Type: :wq
lucky8926
Jun 16, 2007
217
Central IL
On your Mac:
On iPhone:
6. Type: :wq
got it all until step 3.... SSH into your iPhone? I installed SSH but don't see an icon on my iPhone.
420greg
Jun 26, 2007
845
Orlando, Florida
There will not be an icon. In runs in the BSD subsystem.
Download FUGU and use it to ssh to your phone.
Your phone has to be on the same wi-fi network of your mac. It does not need to be cradled.
user: root
pass: dottie
port 22
lucky8926
Jun 16, 2007
217
Central IL
I'm not using wifi, and don't know what ssh'ing my phone means.... I'm a little new to all of this can you explain it kindergarten style for me?;)
420greg
Jun 26, 2007
845
Orlando, Florida
You are going to need to be on wifi with your mac and iPhone for Fugu to connect.
lucky8926
Jun 16, 2007
217
Central IL
So the only way I can get the my ebay to work on my iPhone is if my mac is on a wifi connection?
Tinman
4,334
183
Aridzona
Not necessarily.
You could edit the plist on your Mac, as instructed here:
http://homepage.mac.com/jordy2/ebaywatcher/USA/iPhone.html
(That page has a link to download the app, which contains the plist.)
Once you have the edited plist on your Mac, you could then use Sendspace.com to upload it (you can setup an account if needed, it's free).
Then you could install iShare on the iPhone and use that to download the plist from SendSpace. You'll likely need to delete the copy on the iPhone before downloading.
Mike
lucky8926
Jun 16, 2007
217
Central IL
Sounds like a lot of work just to get a my ebay app on my iPhone! Thanks for the help guys....
davis5050
Aug 18, 2007
192
can u only use this with a mac? I have a pc.
