my harddrive died
theraker007
Jun 15, 2007
322
and so did al my mp3s with it..i still have them on the iPhone, but the next time i synch on my formatted computer im going to lose them all arent i?
is therea way to retrieve these songs off the iPhone? or did i really just loseall my music?
420greg
Jun 26, 2007
845
Orlando, Florida
iPodrip may work. It worked for my iPod video. It moves all the content from your ipod back to the computer.
mach1mustang_101
Jun 30, 2007
59
reformat your hd put everything back on. put iTunes on it then hook it up. it will show up under iPhone then you can just copy to library.
Wangmaster
Jul 6, 2007
35
Sad to say, ipodrip doesn't work on the iPhone. I tried but ipodrip doesn't recognize it as an ipod...:(
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
It's always good to back up that iTunes folder to a large flash drive to avoid those situations. Of course, it might take several flash drives if you've got a lot of music.
theraker007
Jun 15, 2007
322
yes i now know this but it doesn't help me much for my present situation.. so theres really nothing that can be done eh?
skiz420
Jul 28, 2007
371
Boston
as far as getting them off... theres no way i know of yet... but if you have the option for automatic sync turn off on your iPhone then you wont lose them but if you have it auto sync on connection they will be erased...
vansouza
Jul 11, 2007
164
Las Vegas, NV USA
www.usheroes.us
You will have to tell us.
Seems you are a pioneer.. If you have a Mac, iTunes will as if you want to copy your purchased music to the iTunes folder... but you will loose ripped tunes. I have no clue what will happen if you have XP or Vista. Now this is offered as experience with "iPods" not my iPhone. Good luck and let us know... and backup, backup, backup.
