My iPad is going crazy HELP
MuscleMommy
Sep 8, 2011
163
66
I came home and was going to get on my iPad. I put in my pw and it started opening up random apps and web pages and would not let me control it. It was acting as if an invisible kid was on it having a good ole time.
I did a hard restart and it then it went crazy tying stuff in the pw field and locked me out for 3 minutes. I finally got it shut off. What is wrong? I have had it only 2 months. I only use it while at my chemo treatments and take damn good care of it. Ugh does it need to betaken into Apple? I don't have Apple care
Jmbaker429
Jun 28, 2010
994
144
35
if you have done a hard reset already then I would try hooking it to iTunes and see if you can sync it and then do a restore. If that doesn't work ten It needs to go to Apple
Dustu2
Jul 16, 2008
478
Houston, TX
I would imagine that Restoring as new, as stated above, would fix it. However, if you restore and it's still acting up that way... Take it straight to Apple, show them what it's doing, and explain that you already tried restoring. You should have no trouble getting a replacement unit.
Dustu2
Jul 16, 2008
478
Houston, TX
When you start the Restore process via iTunes, it will, at some point, ask if you wish to Restore as New iPhone, or Restore from Last Backup. Just choose the former.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
My phone went crazy last night. Froze up, notification center opened itself up, spinning wheel turned off and stayed on the Apple logo for 5 minutes before turning on again.
Maybe was a crazy Apple iOS day.
Glad to see you're doing ok btw.
  • Like
Reactions: MuscleMommy
Babyt
May 24, 2010
1,013
64
If you bought it brand new 2 months ago.. You should have 10 months of Apple care left
Sent from my SAMSUNG-SGH-I777 using Tapatalk
MuscleMommy
Sep 8, 2011
163
66
Thanks benny- I spent all of december in hospital and christmas I was in ICU. I have had a rough time on chemo so that is why I haven't been around the boards. But I am finally home and taking a chemo break for 3 weeks. :( I had a blockage in my stomach, which required immediate surgery with lots of complications - that ended in me laying in icu with my stomach just open to see all my insides for a week and half.... thank god that is behind me now.
Ok ONE MORE QUESTION - Can I back it up before i take it Apple - with it still going crazy? I checked it this morning and it was still going crazy.... I go to Apple tonight at 8pm.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I don't know how you do it. You are my hero, one of them at least :D
Even if your not around we always wish you the best, and hopefully soon to see you back in full force and healthy.
  • Like
MuscleMommy
Sep 8, 2011
163
66
Thanks Benny! I took my iPad in and they tried a restore which didn't work since I had already tried it. I got a new iPad and now back businesss. I should be around the boards more now that I am at home
