MY iPhone ... HELP
May 4, 2009
i was taking a picture on my iPhonr and then it dropped and then it craashed. I tried to reset it and then it just turned off. I need help turning it back on.. I tried resetting, hooking it up, and i don't know what to do. I don't think i can return it b/c it was jailbroken ... so can anybody help me please...?
AdrianCubed
Jul 19, 2008
3,585
40
London or Miami
You said u dropped it? If it wont turn on then you are sold out of luck unfortunately. You can try taking it to an Apple store and see if they will help you get a replacement, however i doubt this as there is visible damage from a fall. Its still worth a shot tho.
Sorry for your loss.
PepeRB29
Mar 21, 2008
1,500
8 mile
yah that sucks big time. more than likely you are at a complete loss for the product, well you may be able to sell it cheap to someone who buys broken iPhones, but not for much at all.
iNinja
Aug 8, 2008
3,985
20
UK
if theres no visible damage then take it to a genius and say then when trying to sync, your iPhone froze and wouldn't turn on. if he gets it working, great. If not, you get a shiny new one!
May 4, 2009
do they send it in the mail or do they just hand u one?
iNinja
Aug 8, 2008
3,985
20
UK
just hand you one presuming they don't find anything wrong, i.e the water sensor etc.
PepeRB29
Mar 21, 2008
1,500
8 mile
if there is no water damage, no way of them knowing it was physically damaged, or no way they can tell it was jailbroken, then yes they will just hand you a new iPhone.
PepeRB29
Mar 21, 2008
1,500
8 mile
good luck, just play stupid and keep your fingers crossed
5,578
If they get it working, he won't need a new one, so it won't matter ;)
AdrianCubed
Jul 19, 2008
3,585
40
London or Miami
Depends on if he replaced the boot logo. B/c when he turns it on the first thing its going to show is the pineApple or [PWNED!]
5,578
Yep, that's why I never change the boot logo to the pineApple. It's definitely not worth it.
panzeriti
Apr 15, 2009
Sounds like your hosed! Sell it on eBay or Craigs... some people will pick up broken ones to fix em up or whatever.
iNinja
Aug 8, 2008
3,985
20
UK
How did you get on? Did you get a new one?
