My iPhone hung
saplingg
Oct 22, 2007
17
Hi, I need help with my iPhone.
  • It has hung and now I'm stuck on a screen that says "Enter Passcode", with all 4 spaces filled.
  • I can't switch it off.
  • The home button doesn't work
  • I've tried calling it from my home and I hear the ringing tone on my home phone but nothing on the iPhone.
  • The screen is permanently switched on.
  • I've plugged it into my computer and it shows up on my iTunes and begins to sync and everything. But it still remains on that screen
  • I'm using software version 1.0.2, and I don't want to "restore my iPhone".
Is my only option to wait til the battery dies and then restart it? Or is there some way to reboot my iPhone?
Please help, thanks
Jul 18, 2007
Hung iPhone
Please help, thanks
Try Holding down the top (black) and the Menu button for 20 Secs (ignore the message "Slide to power off." You should see the Apple logo. If you don't see it just keep those two buttons held down until you do. Gl.
AquaMan09
Oct 8, 2007
Restore it
Dude Just Restore it...:cool:
Alexander
Jun 28, 2007
1,724
Atlanta
Don't restore it. The first posters advice was correct. Hold those button together until you see the Apple logo, then release.
Sep 29, 2007
348
Holding down the top button and the home button and after 10 seconds releasing the home button places the iPhone into restore mode. Thus making you required to plug it into iTunes and restore.
saplingg
Oct 22, 2007
17
Thanks for the help. I didn't want to restore because I'm running 1.0.2 and if I restore I will have to update to 1.1.1. I just left it like that for about 5 hours and then it ran out of battery. When I plugged it in to the power socket it rebooted and now it works fine.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
yes but if you hold those two buttons down, the phone FIRST shuts off. That's when you let go. If you continue to hold the buttons down, the phone THEN goes into restore mode.
