My iPhone is now an expensive paperweight
slope
Oct 21, 2007
46
Inside my Iphone
Right folks, i think i have completely killed my iPhone beyond repair.
Firstly i am using windows not Mac.
My iPhone was crashing all the time so i decided to restore in iTunes.
I was a bit rash when it would not work so updated it to V1.1.2 with a view to downgrading and jailbreaking.
That is where it all went wrong. It was an unlocked V1.1.1 to start with and when i got the the stage of using ibrick the phone restarted and now scrolls constant white text down the screen aand then after about 10 seconds it reboots and starts again. I can just make out wording like " Darwin Kernel V9" at the top just before it starts the endless scrolling of white text.
Time to throw it in the bin?
HELP
bfakhroo
Oct 2, 2007
132
there's a guy called stevonW something like that he had the " infinite rebooting" problem try to PM him or something maybe he can help u..
djentee
Sep 17, 2007
24
same thing happened to me with the endless reboot. what i did was:
1. Closed iTunes
2. Disconnected iPhone from USB.
3. Restarted iTunes.
4. Hold down HOME + POWER buttons.
5. Reconnect USB to iPhone while holding down HOME & POWER buttons.
This should make iTunes recognize the iPhone again. VOILA!
Hope this helps.
wildonrio
Jul 4, 2007
2,002
Provo, UT
1. Closed iTunes
Hope this helps.
I can testify to this. It always works no matter what, as far as I've seen.
afdal
Sep 23, 2007
29
I also have this prob i tried now, but iTunes is not detedting ma iPhone,
pleasezz help
slope
Oct 21, 2007
46
Inside my Iphone
1. Closed iTunes
Hope this helps.
WOW you guys are good.
Fixed it and allowed me to restore.
I think it will mow be better to wait for an easy Jailbreak as i now am back to a unactivated previously unlocked phone. It now has V1.1.2 when it was an OTB V1.1.1 which i jailbroke and Unlocked using anysim.
Hopefully and easier jailbreak / sim unlock is just around the corner.
Anyhow respect to everyone who has helped.
drac
Sep 17, 2007
grats.... see its nevar to late
Stevonw
Sep 14, 2007
560
UK
Must be a good week for that! ;)
Same thing happened to me two days ago. After some research, I found out it is called "Kernel Panic"
I guess it's a MAC thing.
This happens in OS X and is VERY RARE.
Whereas you have all versions of Windows with the BSOD (Blue Screen Of Death) every 10 minutes :laugh2:.
Oh c'mon, it's not THAT bad! ;)
Besides, I read somewhere that the wrong set of keystrokes on a Mac can actually open a portal to hell.
Not sure on that one.. :p
slope
Oct 21, 2007
46
Inside my Iphone
Update
I now have a fully working and unlocked iPhone again with thats to you guys.
I followed the guide to downgrade to v1.02 then use Putty etc then upgrade to v1.1.1. I then jailbreak and anysim unlock while on 1.1.1. and all works perfectly. Seems really stable too. Boy am i happy. :laugh2:
Stevonw
Sep 14, 2007
560
UK
Update
Glad to hear the forum has helped save another iPhone from the bin (or trash for you Americans LOL :D)
visiukr
Jan 6, 2008
help help, another infinite reboot problem :-(
Update
Hi Slope,
I am running into a similar problem and I am not exactly sure what to do since I am so afraid that I will brick it forever.:confused:
I started with the unlocked iPhone (1.0.2) then I verginized it back to factory condition. Then I upgraded to 1.1.1 and used oktoprep to prepare 1.1.2 jailbrake, I then later successfuly jailbroke the phone.
Everything went well till I use anysim (for 1.1.2 not OTB) which somehow, after it completed, puts iPhone into infinite reboot mode.:oops:
Could I follow your method by using restore to 1.0.2 and start from scratch? :) Any suggestion?
Thanks a heap!
JR
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
you need to get it to the point where it is in and recognizes that your iPhone is in restore mode again..
slope
Oct 21, 2007
46
Inside my Iphone
Try this first to get your pc to find the device. Then resotre 1.1.1 and go from there.
I will try and dig out the full guide i used.
I have it somewhere.
1. Closed iTunes
visiukr
Jan 6, 2008
1. Closed iTunes
Thank! I will try this.... Is it ok to downgrade to 1.1.1 after I unlocked?
JR
