my iPhone is stuck
UncleSam
Feb 29, 2008
I was just uninstalling some apps using Installer because I had too much unused apps. After uninstalling them i restarted my iPhone and the iPhone is now stuck at the Apple logo and it keeps restarting. I tried to connect it to my pc and the weird thing is that iTunes detected so i performed a Sync.
Now what should i do ? can i use ZiPhone to make it work ? ?
please don't tell to restore it and re jailbreak it.
Note : I have a 1.1.4 jailbroken iPhone. and I have attached a picture showing where im stuck
Thanks.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
This happened to my phone a while back. The only fix that I know of is to restore and re-jailbreak everything. I had to plug the phone into the computer about 50 times before it finally registered. Jailbreaking on ziPhone is rather easy anyway, so it shouldn't be that bad.
