My iPhone is stuck
Apr 26, 2008
Hi, Just got an unlocked iPhone as a gift. A friend tried to help by adding software to resolve my bluetooth issue (not working). I have no clue what he downloaded neither does he. Anyway the iPhone is know stuck. I found out from the internet how to perform a hard reset. I did that but all I get is the visual of the Apple. Can anyone help:(? Thanks
psylichon
Oct 31, 2007
16,591
751
40
Philly
"visual of the Apple"? Do you only get the Apple logo or does it tell you to connect to iTunes?
Apr 26, 2008
Apr 26, 2008
Thanks I did exactly as pointed out on the url but I'm only getting the Apple logo after the 30" wait. If I stay holding then the iPhone goes off.
I'm not getting any yellow triangle or a msg to connect to iTunes.
psylichon
Oct 31, 2007
16,591
751
40
Philly
have you tried (with the iPhone off) holding the power button while connecting to iTunes? This is another way to force a restore.
Apr 26, 2008
Just tried your suggestion but to no avail !
