My iPhone keeps connecting and un-connecting why trying to sync?
Medeiros2227
Jun 21, 2007
33
dunno
Why I try to sync my iPhone, it will connect and un-connect repeatedly? Any suggestions?
mewsha29
Jun 26, 2007
Same problem here... fixed
Take your cable to Apple store and exchange. Mine fixed after that.
iPhoneJones
Jul 13, 2007
52
I get the same thing and iTunes won't start when I connect to the front USB hub. I get a phantom Dadunk without my iPhone being plugged in at all. Weird.
sp33d
Aug 28, 2007
Check your drivers... also try starting iTunes manually. I think there is a setting that allows you to connect without bringing up iTunes which is probably what is happening if you hear the dading.
